![]() Drives: yaris 2007 Join Date: Oct 2014
ok
I have the Multimeter now |
OK. Let's start with the following:
1. With the headlight switch on or off, Measure the voltage on the white wire in pin 13 of the headlight switch connector. Touch the red lead to the pin where the wire enters the back of the connector. hold the black lead against a chassis ground point (Metal structure under the dash or any white wire with a black stripe). 2. With the headlight switch on, measure the voltage on the green wire in pin 10 of the headlight switch connector.
| park lights not working | koppe | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 06-06-2025 02:24 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| Rear break/STOP lights, tail lights are out, plate lights working? | MzTyla | DIY / Maintenance / Service | 2 | 06-20-2013 07:56 PM |
| Fog lights, or parking lights stopped working | sylvermagyk | DIY / Maintenance / Service | 4 | 03-24-2011 05:13 PM |
| Taillights, signal lights, parking lights stop working | jamal1984 | DIY / Maintenance / Service | 2 | 10-13-2010 10:17 AM |
