Old 02-04-2015, 02:59 PM   #1
jwpaine
Drives: Yaris 5-speed Hatchback
Inner tie rod replacement - rack assembly?
Hello,
I failed inspection due to 'play' in the right inner tie rod of my 2007 Yaris. I was told by the place performing the inspection that the inner tie rod quote "Wasn't a serviceable part" and that the entire "Rack Assembly" would have to be replaced. Is this true, or am I being sold?
Thank you!
jwpaine is offline   Reply With Quote
Old 02-04-2015, 07:22 PM   #2
mimelio
Drives: NONE
Originally Posted by jwpaine View Post
Hello,
Thank you!
That's not so
http://www.autopartswarehouse.com/sk...P10410738.html
Time to go somewhere else that knows front end work.
mimelio is offline   Reply With Quote
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
trouble with tie rod nut BobTheYaris DIY / Maintenance / Service 3 04-07-2014 07:08 AM
WTB Battery Tie Down Rod Altitude Willing to Buy by private party 3 01-07-2013 10:45 AM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
