Old 02-23-2015, 02:20 AM   #4
man83
Drives: Yaris HB
Thumbs up
Originally Posted by dragoonmc View Post
Look for the sensor attached to the intake tube. It has a hose running to it and out of it as well as an electrical connection. That should do you. You can also use the brake booster hose(might be the same hose) or the pcv hose but this will have some oil and moisture in it
Thanks dragoonmc, I just made the installation, always in the purge valve system, but before the sensor. Now the gauge runs well.
Previously I had done after the sensor.
VELMAX member.
man83 is offline   Reply With Quote
HVAC dripping water when AC on. Drain hose is NOT clogged. kustomrtr DIY / Maintenance / Service 3 09-07-2014 09:45 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
vacuum hose / heater hose size cali yaris Performance Modifications 12 05-17-2013 09:58 PM
Where is are all the vacuum hoses sourced? LtNoogie Performance Modifications 1 05-17-2009 04:22 PM
