How To Make Your Clutch Last Forever!
Im 59 this year and have never replaced any part of a clutch in any of my vehicles. The clutch in my 74 VW went 250,000 miles.
Heres how I did it! 1) No holding the clutch in at lights. 2) Never slip the clutch except when moving off in 1st. And as little as possible then. 3) Use no throttle when shifting except when moving off in 1st. And as little as possible then. 4) Clutch pedal must be either on the floor or up in the air with your foot off it. If you can do this your clutch will reward you with long life!
#2 | |
![]() ![]() And if you're just learning, tires are cheaper than a clutch replacement. |
WOT shifting...
Mr. 155 and climbing
You can pick up a clutch for 300. Tires worth having will run you 80+ pop ;-)
2ZR swap. DO IT! Ask how!
lol...this is true even with this car!
I give a little throttle to rev match when going from 1-2 and 2-3, this makes for a smoother shift and should decrease the wear on a clutch
#8 | |
Revs DROP when going up through the gears.
#9 | |
It depends on how fast you change gears, as well as how fast your crankshaft winds down. If you have a lightweight crank pulley and/or flywheel, you will likely have to blip the throttle when upshifting as well.
Rev match is definitely not the right word (although I do that when shifting down all the time to save the clutch). I give a slight bit of gas when letting out the clutch from 1-2 and even less from 2-3 gear. It gets rid of the rough shift normally found in low gear shifts.
Feel free to chime in as to why giving no gas at all at low gear shifts causing a rough shift and giving gas smooths it out. I'm assuming it's the same reason why you need to give a bit of throttle going from stop to 1st. Due to the lag of a slow moving transmission and a faster moving engine. Giving it gas helps ease the connection between the two. |
DIYer
Drives: yaris 1.5 MT Join Date: Oct 2014
i thought this was basic knowledge, yet i see a lot of peoples cars rocking back and forward on hills because they were holding it with the clutch, its infuriating to watch. :P
many times waiting for the revs to drop when changing from 1-2 can take what feels like a few weeks, so most of the time i say screw it, im slippin ya. |
#13 | |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
#14 |
![]() Drives: 2009 Yaris Join Date: Apr 2015
Speaking of saving clutches? Does anyone here ever shift up to higher gear without using clutch?
#15 |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
I don't think so, would be too much stress for the transmission.
I drive, therefore I am. |
#16 | |
The rest of the clutch was good?
#17 | |
| Riding the clutch in a yaris | negev | DIY / Maintenance / Service | 23 | 07-19-2013 11:11 AM |
| possible clutch gone bad? | DevilGirl | DIY / Maintenance / Service | 19 | 11-15-2012 06:29 AM |
| I make guitars. Not 56k friendly. | anomoly40 | Off-topic / Other Cars / Everything else Discussions | 11 | 07-29-2012 03:52 PM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
