Old 08-19-2015, 01:10 PM   #1
otterhere
Drives: 2008 Yaris 3-door Meteorite
Maintenance Light at 80k
Any idea why this has come on? Not time for an oil change. Car running fine.
otterhere is offline   Reply With Quote
Old 08-19-2015, 02:54 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Maintenance light turns on every 5k miles since last reset.
BTW, you could go on forever without oil change and still be "fine".
Sent from my A0001 using Tapatalk
Old 08-19-2015, 04:09 PM   #3
otterhere
Probably...
But what I'm saying is that it hasn't been 5k miles since it was last on (when I was last due for an oil change, which is why it comes on every 5k miles)...
It's only been less than 1k miles and it's on again, so is there some other "recommended maintenance" that would trigger this at 80k?
Old 08-19-2015, 06:30 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
They just probably forgot to reset it last time.
Old 08-19-2015, 07:32 PM   #5
ex-x-fire
Old 08-22-2015, 05:56 PM   #6
tomm9050
Drives: Yaris 2008 HB
How do you go about resetting the maint light?
tomm9050 is offline   Reply With Quote
Old 08-22-2015, 06:07 PM   #7
bronsin
bronsin's Avatar
Set the odometer to Trip One and turn off the ignition. (the selections are ODO, Trip 1, and Trip 2)
With the ignition off hold the odo changing lever in. Turn on the ignition with continuing to hold the lever in.
Done.
Old 08-22-2015, 10:53 PM   #8
tomm9050
Thanks!!
Is Maintenance Required Light ONLY for oil change reminder? Fatty Lumps DIY / Maintenance / Service 2 07-01-2013 09:44 AM
HELP / Spoiler connecting light SimTronik DIY / Maintenance / Service 4 11-02-2010 11:08 PM
What to look for with maintenance needed light on? 09box DIY / Maintenance / Service 3 09-24-2009 01:11 AM
Maintenance Light Comes on? JetfireK General Yaris / Vitz Discussion 7 03-07-2009 04:54 PM
