$10.25/hr frying chicken
45mpg
It seems with age my Yaris is getting better mpg, last take recorded 45.12mpg 440 miles on 9.75 gallons of regular 87. I drive a 2012 stick with 31000 miles on the odometer. For mods I have removed the hubcaps, rear seats, and spare tire. This was all suburban driving with some A/C usage.
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Nice! My engine only has 320 miles on it thus far, and is probably still in the "break-in" phase.
![]() I'm still getting accustomed to the smaller (11g?) gas tank in my Yaris, which creates the illusion (according to gauge level at end of week) that I am going through more gas per week than my old 2000 m/t Accord EX Sedan (w/17g tank). ![]() I will be doing my first gas tank refill later today after work. On my Accord, I had to put around $25-28 into the tank each week just to get from around half back to full tank. The same amount of money on my Yaris should take me from nearly empty back up to full, at current prices. I have no idea what gas mileage I am getting on my Yaris currently, while doing my normal weekly routine. I will have to watch it more closely this coming week and see what I am coming in at for MPG. - Last edited by Kalispel; 08-21-2015 at 03:06 PM. |
Looks like you drive an SE? I am tempted to trade up... There is a black stick shift one locally too.
#4 | |
#5 | |
#6 | |
#7 | |
. I followed what some others have posted and assumed that the avg mpg reading = for the life of the car and isn't able to be reset. Don't know if the '12-'14 can't be reset, or if those years are the same as the '15 . I should probably look at the owner's manual . I've never reset mine, and it shows 40.6 MPG. Others have pointed out that this gauge probably overstates because when you take your foot off the gas, etc. the gauge often goes to 99.9, and you really aren't getting 99.9 MPG during those (albeit short) periods.
#8 | |
I prefer the 'average' MPG function. When I pressed the button and held it down, the old 32.X 'average' reset to 0, and then seemed to restart from that point on - as it was less then 20mpg for the first few minutes of driving, while leaving my house and poking around my neighborhood streets in 1st/2nd gear before hitting the main road. The'average' display on mine never jumps around, and slowly either goes up or down by 0.1 (or stays the same) as you drive under different conditions. - |
#9 | |
(it would probably make sense that this is a function that also exists on the '12-'14...I just didn't know about it re only scanning the owner's manual). The display on my 'Average MPG Gauge' behaves just like your description re your 'Average MPG Gauge', and the display on my 'Instantaneous MPG Gauge' behaves just like your description re your 'Instantaneous MPG Gauge'. When other posters have mentioned the '99.9' on the 'instantaneous MPG Gauge' in various posts, they have usually done so (at least in my observation) re how the '99.9' MPG on the 'Instantaneous MPG Gauge' ends up effecting (overstating) the Average MPG reading. These past posts led me to think that the Average MPG Gauge 'Calculates' using (fully or partially) some sort of sampling of the 'Instantaneous MPG'. Those past posts from others re the effect any '99.9' instantaneous readings have on the 'Average MPG reading' could be 'all wet', so to speak .I just use the 'Average MPG Gauge' as a guide. I still do an old school written log book, and calculate each tank separately. |
#10 | |
- Last edited by Kalispel; 08-28-2015 at 01:33 PM. |
#11 | |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
Every now and then I get in a hurry, and actually keep up with the traffic on the short stretch of Interstate I traverse to get to town, 80 MPH speed limit! I use the air con. a lot also. I STILL am getting over 40 MPG averaged out over the last 3 years. I also from time to time, floor it and damn it's pretty zippy too. No hub caps, spare, rear seat, jack, etc. Mid 40's very easy to achieve when driven as usual. 80K miles.
Just for your info, on my 2014 SE the trip computer usually reads about 1.5 mpg higher than actual pen and paper calculation.
#14 | |
Only Happy When it Rains
Or more likely you are getting better driving it gently.
Colin Chapman disciple |
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
I also have the 2012 Yaris (M/T). I the summer, almost every tank is over 40mpg, unless I do a lot of 70+mph freeway driving. 43mpg per tank is probably average. My current tank is at 47.5mpg with a bunch of careful driving (and warm weather). In the winter, my mileage probably drops by 1/4 or so, unfortunately.
| 28mpg to 45mpg city/highway | Red Horse | Fuel Economy Forum | 2 | 09-07-2012 10:29 PM |
