Old 09-27-2015, 06:50 PM   #11
Tanes70
Drives: 2010 gray Yaris
I have installed three myself based on my guide. Did you install a transponder key bypass module, as one will be necessary on any 09+ due to the immobilizer.
Yes, I installed the bypass module, and it's all set. I was reading in this forum and realized that I connect the start wire to the black wire on the starter harness so probably that's the problem, so I have to find the TVIP OEM Alarm connector which I don't know where is located at, and connect the start wire on Pin #12... Also how I know if I should connect the (+) Ignition Output to the pin 9 on the TVIP OEM Alarm connector?
Thanks again for your quick response.
Tanes70 is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
