Old 09-29-2015, 06:00 PM   #7
Originally Posted by ntokozo View Post
thanks Scott. I agree with you. yesterday I checked another yaris. I could not locate the rings. they must be intergrated into the hub.
Thanks a lot. now I have to check the sensor itself. would it mean I might have to change the bearings? usually the rotor is on the bearing than the hub.
Correct - They are part of the bearing assembly. By the way, check out this post for information on how to read the ABS error codes:
http://www.yarisworld.com/forums/sho...&postcount=262
