Old 10-12-2015, 01:41 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
Sounds like they gave you a bullshit line to cover their arses.
It is not uncommon for an installer to over-inflate tires when mounting to get the bead set. However they should then drop the pressure down to the manufacturers spec for your vehicle. They didn't finish the job.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
diff. tire size should mean put diff. psi right? ezhacker1 Fuel Economy Forum 10 01-14-2010 06:48 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
