Old 01-11-2010, 02:10 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
diff. tire size should mean put diff. psi right?
from stock 185/60/15 to my current 205/50/15, my current tires are smaller. I currently have them inflated to 32psi, do different tire sizes mean i should change the psi?
Check out my Build thread:
Old 01-11-2010, 04:42 AM   #2
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
It says on the side wall of the tire. Thats what I would go with.
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 01-11-2010, 06:28 AM   #3
Brentorius
Drives: 07 Mazda MX5 Copper Red
I would say no; 35 psi and call it a day.
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 01-11-2010, 10:46 AM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Your owners manual or the sticker on the drivers side door jamb should give you the correct tire pressure..
Old 01-11-2010, 11:24 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
The sticker on your door jam will give you a tire pressure number that will give you the best overall ride quality/economy/and wear. You can adjust up the tire pressure if you like but i wouldnt suggest going down lower than the recomended tire pressure. Whatever you do dont exceed the number that says maximum tire pressure on the sidewall of the tire.
Id say 35 is a good cross between handling and without making the ride too harsh. 40 is good if you want more fuel economy and less sidewall flex for hard turns but things will start to get little harsh on potholes from there.
Im sure theres lots of people that will chime in. Many many posts related to tire pressure.
Old 01-11-2010, 01:27 PM   #6
ezhacker1
ezhacker1's Avatar
i was under the assumption that the door jab psi recommendation was for stock size tires. Though that different size tires would need different tire pressure.
Old 01-11-2010, 01:36 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I too don't think the doorjamb sticker is relevant unless you are running stock tires or tires that are of the same size as stock.
Old 01-13-2010, 01:53 PM   #8
ezhacker1
ezhacker1's Avatar
anyone else know? size different, different pressure than doorjab?
Old 01-13-2010, 02:25 PM   #9
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Depends on your goals. Also depends on the specific tire.
Whatever the door sticker says should be safe and adequate for any size tire you could reasonably fit on a Yaris. If all you want to do is be safe and adequate, run with that.
If you want better steering response and/or less rolling resistance (better fuel economy) at the expense of ride quality, try experimenting with higher tire pressures up to whatever is stated on the sidewall of the tire.
You can't go wrong with 32-35 psi as a general rule for the typical commuter. Something in the 40 psi range will help most tires deliver sharper steering response. And hardcore hypermilers will swear by running 50-60 psi to get the best economy.
If you're an aggressive driver, look at your tires, they will tell you what pressure to run. Look at the edges of your tires. Is the tread rolling over onto the sidewall area when you take corners? If so, you don't have enough pressure. You can even use the old autocrosser's trick of marking the edge of the tread/sidewall with chalk or white shoe polish to show exactly how far the tread is rolling over.
Old 01-13-2010, 03:01 PM   #10
127.0.0.1
doorjamb is the best to go with regardless of size, and you get closest to the vehicle design and handling parameters that way.
35 psi setting is a catch-all... general -60% of the time, it works every time-
going up to sidewall pressure will give a rough ride, and make braking harder on bumps
Old 01-14-2010, 06:48 AM   #11
Black Yaris
der Zeck
Black Yaris's Avatar
wrong, that is the MAX tire pressure
32 is the recommended tire pressure
Loren has explained the reasons for higher tire pressures well enough
How are you guys jacking up your Yaris? touroxin DIY / Maintenance / Service 65 02-01-2015 04:42 PM
Tire Size db662 General Yaris / Vitz Discussion 4 10-27-2009 11:09 PM
Tire Wear Analysis Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-13-2009 09:28 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
