Old 10-27-2009, 05:18 PM   #1
db662
Drives: 2010 yaris
Tire Size
Does anyone know if you can put P195/60R15's on a stock yaris 15 inch rim? Mine came with P185/60 15. Will going up the extra size cause any damage to the transmission or engine?
db662 is offline   Reply With Quote
Old 10-27-2009, 05:19 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
no. they'll fit fine, they'll just make they speedometer a tad innacurate.
http://1010tires.com/tiresizecalcula...?action=submit
Colin Chapman disciple
Old 10-27-2009, 05:29 PM   #3
db662
Drives: 2010 yaris
Great thanks. Do you know if you can go up to 205's? or what the largest width is that you can put on the stock rim without really starting to mess up the tranny or engine?
Old 10-27-2009, 11:06 PM   #4
Kal-El
Kal-El's Avatar
205's will fit, but you should probably go down to 55 series.
My Yaris, bought used certified, actually came with 215/50-15's. An odd size but they work without any issues. So 215 is the widest you can go.
Old 10-27-2009, 11:09 PM   #5
why?
why?'s Avatar
Drives: Yaris LB
you aren't going to mess up the engine at all by adding wider tires. What you might get is the tire rubbing on tight turns, or bigger bumps. it will also effect your acceleration, mpg, and handling as well. The first two will be effected negatively, the latter could be effected positively.
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
Tire Size Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-09-2007 12:28 PM
Tire size? JDMVitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-21-2007 11:03 AM
