2ZR swap. DO IT! Ask how!
Ok, that's pretty much what I was thinking, but it's always good to have someone confirm it. The cable throttle is a must, since the MR2 is cable as well. I'm debating if I want a bigger throttle body to go with the S/C--mostly because of the limited options in OEM upgrades and lack of IAC on an aftermarket universal unit.
From this 2001 Echo listing on ebay it looks like the main wire harness uses three of the ECU connectors, but one of the two other white connectors nearby may be related. I'll spend some time over the next few days putting a ratsnest together in EagleCAD to see what ends up going where. |
#2 | |
There are 4 connectors which go to ECM on the Echo.
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 03:12 PM |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 12:34 PM |
| Blitz S/C being installed this Saturday! | LtNoogie | Forced Induction Forum | 179 | 12-14-2012 09:53 PM |
| Does anyone know what wire harness is in the 09? | Yarrris-Wench | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 05-27-2010 08:44 PM |
