Old 12-31-2015, 11:52 AM   #21
tmontague
tmontague's Avatar
I disconnected the white connector from the module and stuck a paper clip in the H1/10 and the H1/3 which is a ground for the dome light. Sure enough the parking lights (front and rear) went on.
So I'm assuming that this means that my wiring and taps are obviously fine but there is an issue with the viper module not grounding the parking lights? I'm going to read the instructions and see if I only need a new module that I can then program my fob's to or if that is not possible and I need a module with new fob's as well.
Any other possibilities or things that I could do to fix this? I'm hoping the ebay seller will send me a module free of charge but if this is something that I can fix fairly easy myself to get the module to ground properly then I'd rather just do it myself and save waiting for a new module.
CTScott do you know of a way to fix the module to properly ground?
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
