Old 01-03-2016, 10:11 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yeah, the engineering world is surprisingly cutthroat when it comes to knockoffs.
I spent a bit more time today going over the wire harness. Took off all the A/T stuff that isn't needed, made a few pin swaps to get some M/T wiring in the right spot, and started cleaning up my wiring schematic. Looks like the harness I bought is missing the TPS--bastards just chopped it right off instead of removing it. There are still about 10 wires on the E4 connector, since I don't know for sure what signals the ECU requires to operate. I'm going to put together a spreadsheet with the pinouts of each ECU connector to help with collaboration.
I also scored a '14 Yaris A/T ECU and engine wire harness today as well, with the intention of making a piggyback wire harness adapter from it.
Old 01-03-2016, 10:21 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Same pinout as our current gen TPS?
Also what are you going to do about the throttle body and IM?
Sent from m-o-b-i-l-e
Old 01-04-2016, 06:43 AM   #3
CrankyOldMan
No, it's the previous gen with separate TPS and IAC valve.
I'm not 100% sure what the plan is for IM. Somewhere between all OEM bits, a 1ZZ (cable) TB, and the Blitz S/C. I had also debated using the Yaris manifold and adapting a universal TB, but that means no IAC--which may be a pain in the ass.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Does anyone know what wire harness is in the 09? Yarrris-Wench In Car Entertainment + Electronics (audio / video / alarm) 2 05-27-2010 07:44 PM
