Drives: Yaris 06 Join Date: Dec 2010
Hi guys,
I've lost my master keys (yes both), father in-law lost one, and now i lost mine... I searched through the forum and found out that i need to find my FCCID on the user manual, however, it stated that "For vehicles sold in USA"... These are my numbers: FFC ID: MOZB41TG FFC ID: MOZB21RG Then on the side there is a section stating that this decide compiles with RSS-210 in Canada. So can i still use the FFC ID stated in the manual to find my fob? Or should i be looking for RSS-210? I've dig through eBay, and only saw this key with FFC ID: MOZB41TG, however, the look of my original key is slightly different... Could some of you confirm whether i could use the MOZB41TG? Much appreciated with your help! Thank you in advance. Eric Last edited by codenamezero; 12-10-2010 at 09:54 AM. |
You are looking for ones with the FFC ID: MOZB41TG. The other FCC ID is the one for the receiver. The MOZB41TG has been around for a while, so there are a couple of variations in the plastic case.
![]() Drives: 2007 Yaris S Sedan Join Date: Jan 2016
Yaris button remote key and door remote receiver
I was looking at this post and wanted to check if in fact the MOZB41TG key and the MOZB21RG receiver will work together I have both butt have not yet been able to get them to work together
No. They will not. 41TG works with 41RG only and 21TG works with 21RG only.
Thanks for the info I have installed the factory fog light set up from a YouTube video that gave you credit for the info CTScott so thank you for that one two
#6 | |
MOZB41TG is the FCC ID for the transmitter and MOZB21RG is the receiver. The receiver part number is 89741-52390 for the Yaris hatchback and Scion Xd, and 89741-52290 for the Yaris Sedan. Although the part number are different, both fall under the MOZB21RG listing.
| How to tell if my Yaris has Keyless Entry... | ross sez | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 02-01-2011 11:49 AM |
| I lost my master keyless entry key, need suggestions.... | Frankd1 | DIY / Maintenance / Service | 19 | 12-01-2010 11:13 PM |
| Key fob locks but won't unlock | Pingouin | DIY / Maintenance / Service | 2 | 09-15-2010 03:53 PM |
| Keyless question | lita_g | In Car Entertainment + Electronics (audio / video / alarm) | 45 | 08-11-2009 11:13 AM |
| keyless entry? / security? | mem | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 10-22-2008 01:29 AM |
