![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
gasket
I was told that the gasket/washer for a new transaxle drain plug was 90430-18008 part no.Toyota.
But when I ordered it the Toyota website changed it automatically to 90430-A0003 DRAIN PLUG GASKET This should be an aluminum flat washer. I dont want a steel one. can anyone confirm that is is the right one and aluminum?? |
90430-18008 is what was correct for both AT and MT and was aluminum. It was indeed replaced by 90430-A0003, which is steel.
Dorman 095-149 is an equivalent in aluminum.
is steel gonna hurt the aluminum seat on the Yaris trans??
I don't think so, which is likely why Toyota changed to steel.
I got my stuff from Toyota Parts and the 90430-A0003 washers are aluminum,not steel.
I also changed to hex head plugs and it is better. What I really need now is a detailed pictorial on removing the trans for new bearings and a new clutch. |
| Front Exhaust Gasket Replacement | tmontague | DIY / Maintenance / Service | 6 | 03-25-2015 10:00 PM |
| 07 Yaris S Blown Head Gasket? | ylerT | DIY / Maintenance / Service | 7 | 06-26-2013 01:19 PM |
| Head gasket | thefalls | Forced Induction Forum | 12 | 11-12-2012 12:26 AM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
| Hood gasket | acrbill | General Yaris / Vitz Discussion | 0 | 01-05-2007 08:03 PM |
