Old 11-12-2014, 08:46 PM   #1
japle
japle's Avatar
Drives: Vitz S 2007 LB
My Dyno Run
guys, this is my cars dyno run... the car came as an 1.5s 1nz-fe, auto, full stock, for some reason it was equipped with a 2nz-fe intake manifold, dont ask why, i got this car used from a car dealer.
my 1st original run, 1zz-fe throttle body, 4-2-1 header, stock mid and blitz nur-spec S-Flow Exhaust, nothing else.
2nd run, after a lot of 4-2-1 and 4-1 debates, switched back to the 1nz-fe throttle body, after that i bought a 4-1 header, 0.2mm thick, mandrel-bent full stainless steel piping with a huge S-Flow midbox, wouldn't say its fully S-Flow, it just enters from the top in the inlet, appears middle in the outlet, both 2 inches wide, full stainless again to the rear, then the blitz nur-spec S-Flow Exhaust
3rd run, after that was done, i did a lot of research regarding the differences of 1nz-fe intake manifold and the 2nz-fe intake manifold, got the same responses, they are the same, not satisfied,i got myself the 1nz-fe intake manifold, plugged it in with the 1nz-fe throttle body, got myself this, a headspinner.
CRAZY, 14whp!
4th run, this time i did the 1nz-fe to the 1zz-fe throttlebody transplant, but noticing the difference between 46mm and 55mm, i decided to create a spacer that would downsize the hole, to create a better airflow, and i got this
bear in mind that all these are done without the engine management control..
more to come......
japle is offline   Reply With Quote
Old 11-12-2014, 08:48 PM   #2
japle
japle's Avatar
sorry guys, i did not resize it for better viewing, haha..
Old 11-12-2014, 09:43 PM   #3
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
I'm amazed great numbers... The difference has to be really noticeable when you floor it
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-12-2014, 10:55 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
At first i was like...wtf...but then i read.
Nice work...still a little low...i dunno if thats gas or automatic or what but your close to where it should be
For reference mine was 107/104 with just a full exhaust...now its 105/104 (with more midrange torque) with a Tooter spacer and a short ram (power was even less with the stock airbox and the Tooter...like 103/103). My part throttle torque still amazes me
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 11-13-2014, 01:48 AM   #5
japle
japle's Avatar
Ragnacat: its quite noticeable...
malibuguy: yes, its quite low, its gas, automatic and i am still not impressed yet. i do get that my car is a bit shy when it comes to full throttle, it sort of going up the steps, lots of torque, then it slows, then repeats, not so much of noticeable, but its there, i can feel it, anyone experienced this kind of symptoms before?
Old 11-13-2014, 06:06 AM   #6
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
so the 2nz intake manifold realy is crap huh?
Thanks for the post
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 11-13-2014, 07:34 AM   #7
japle
japle's Avatar
Its not crap, but 1nz-fe intake manifold is a recommended upgrade, based on the dyno charts..
Old 11-13-2014, 09:28 AM   #8
BoostedTRD
Drives: 09 Yaris Hatchback
if you don't mind me asking, How much did it cost to dyno your car? I would like to get my car dynoed before going turbo.
BoostedTRD is offline   Reply With Quote
Old 11-13-2014, 09:44 PM   #9
malibuguy
Obsessed with 1.5L
I meant more about the quality of the gas
-96 Tercel 4dr
Old 11-14-2014, 09:15 PM   #10
japle
japle's Avatar
its RM60 in malaysia, so roughly, 18 bucks in america
Old 11-14-2014, 09:16 PM   #11
japle
japle's Avatar
quality of the gas is ron 95 here in malaysia
Old 04-10-2016, 04:32 AM   #12
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Woah another brother from malaysia!
TRD SPEC is offline   Reply With Quote
Mighty yaris dyno run! >:D Black_griffin6 Photo-Video-Media Gallery 0 01-02-2014 11:04 AM
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
dyno day psychopinay42 California 1 08-03-2009 03:42 AM
Dyno and Videos ruimond Photo-Video-Media Gallery 23 02-01-2009 07:34 AM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
