Old 02-02-2017, 08:46 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I don't have the second O2 sensor hooked up, so it runs a bit rich. Fuel economy at WOT all the time is comparable to the 1NZ with a Blitz supercharger. XD
Old 02-03-2017, 09:19 AM   #2
tmontague
tmontague's Avatar
any chance you can give a description of how you added the wire to the fuse box from the fuse to the connector?
Does the fuse box just lift up to give you access? I like the clean look of it
Old 02-03-2017, 10:14 AM   #3
CrankyOldMan
Take a look at the pictures on the front page. It's hard to get a good shot though, because it's all black plastic. Basically, I just populated one of the empty fuse slots and plugged the other end into the empty position on the connector. You have to separate the two bottom parts. There's 7 or 8 tabs that hold them together, and it's more easily accomplished with the fuse box unbolted from the frame. If you get one from a junk yard and break it down, it will make much more sense. I think just about any Toyota fuse box would be OK, but a Yaris or Echo would be best.
Old 02-03-2017, 10:47 AM   #4
tmontague
tmontague's Avatar
thanks. So the female end of the wire is what the new fuse (in the original empty slot) would plug into and then the male end goes under and then up into the connector for the power to the maf, correct?
I think I'm going to my local you pull as I have yet to stop in and it is only about 5 mins from my place. They much have a yaris in their massive lot, or at the very least a corolla. I have yet to pull a fuse box so I want to familiarize myself with what I'm working with before I pull my own
Old 02-03-2017, 11:06 AM   #5
CrankyOldMan
Correct.
Lots of yards have online listing of their availability. I've also got one in my spare parts bin if you just want to play with it.
Old 03-07-2017, 08:33 AM   #6
CrankyOldMan
ArmstrongRacing and I will be happy to assist in any way we can!
Old 11-07-2018, 01:34 AM   #7
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
#4
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
