That is not the radiator - it is the overflow tank, which mounts to the radiator, but is only connected by the little hose from the radiator fill neck. The radiator cap is on the upper hose. Remove that (not hot) and check to see if you have coolant in the system.
| Tags |
| radiator |
| Radiator Fan not working.. | Beubeu | DIY / Maintenance / Service | 3 | 09-21-2015 12:53 PM |
| 2007 Yaris Radiator Fan | kcanaj | Yaris TS Talk | 1 | 07-25-2015 09:13 PM |
| radiator small leak | esse10 | DIY / Maintenance / Service | 2 | 08-20-2013 11:40 AM |
| Radiator Change | TMR3 | DIY / Maintenance / Service | 5 | 06-22-2012 12:11 PM |
| Radiator hose size | window_lee | General Yaris / Vitz Discussion | 0 | 03-31-2009 06:33 AM |
