Ugh.. drifters...
This is exactly what I thought of, with a hub spacer doing the job of mounting a caliper, using toyota parts.
https://www.youtube.com/watch?v=3YhUv4cBoiA |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
That is pretty much what I was shooting for, also. I plan on getting back to this, and soon as I can get some of my car sold off and taken care of.
The 99 camry/solara parts won't work without a good bit of machining. The rear hub leaves the ABS reluctor wheel exposed so the center hole is a good bit smaller. So I am gonna get a set of rear knuckles from a newer model and see where that leaves me.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed. Future: Turbo. |
2ZR swap. DO IT! Ask how!
I've got the setup off an 09 vibe. While it looks tempting in the exploded parts diagrams, it's clearly not a match in any way. I think I'm going to keep the Yaris bits but return the Vibe hubs and splash guards. The calipers look like they might be promising, as they don't have an internal drum parking brake.
![]() ![]() ![]() Drives: 2007 Toyota Yaris S Sedan Join Date: Jul 2007
Here's everything you need for a complete bolt up rear disc brake conversion.
Rr Axle Beam 42110-0D181 R Rr Brake Caliper 47830-52090/47830-52161 L Rr Brake Caliper 47850-52090/47850-52161 Rr Caliper Sliding Pin Bolts 90015-AA102 Rr Caliper Sliding Pins 47835-12150 Rr Caliper Bkt R/L 47821-12150 (11-14 CT200) Rr Caliper Bkt Bolt 90105-10404 Rr Brake Rotors 42431-0D110 Rr Brake Rotor Shields 47803-52010/47804-52010 Rr Brake Pads 04466-52130 Rr Brake Pad Shim Kit 04946-52080 Rr Brake Pad Fitting Kit 04948-52040 Rr Brake Hoses 90947-T2033 Rh Parking Brake Cable 46420-0D130 Lh Parking Brake Cable 46430-0D130
![]() http://www.youtube.com/watch?v=YnTlNLz9Iqc http://money.cnn.com/galleries/2010/...le_cars/5.html http://www.subcompactculture.com/200...-miles-on.html |
#6 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
OT: Been a while, nice to hear from the Grand Master :)
Anyway, excited to know the updated mileage your yaris have at the moment Godspeed! Quote:
Drives: 2011 black yaris Join Date: Sep 2023
does the toyota c-hr disc fit the 2011 yaris
![]() Drives: 2008 dailycross beater on B14s Join Date: Dec 2021
| DIY - Standing rear wiper for hatchback | sex | DIY / Maintenance / Service | 42 | 10-17-2018 06:32 AM |
| Runstop rear brake conversion parts | computerlove87 | Performance Modifications | 2 | 03-30-2016 08:34 AM |
| DIY Sedan rear bumper removal? | gabriel2012 | DIY / Maintenance / Service | 0 | 11-07-2014 06:42 PM |
| Vitz Rear Wheel conversion | Asif | Cosmetic Modifications (Exterior/Interior) | 18 | 01-09-2013 09:47 AM |
