Old 06-11-2016, 04:59 AM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Ugh.. drifters...
-Derrick-
Old 07-07-2016, 02:08 AM   #20
enviri
enviri's Avatar
Drives: 2010 Yaris
This is exactly what I thought of, with a hub spacer doing the job of mounting a caliper, using toyota parts.
https://www.youtube.com/watch?v=3YhUv4cBoiA
Old 07-07-2016, 06:11 PM   #21
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
That is pretty much what I was shooting for, also. I plan on getting back to this, and soon as I can get some of my car sold off and taken care of.
The 99 camry/solara parts won't work without a good bit of machining. The rear hub leaves the ABS reluctor wheel exposed so the center hole is a good bit smaller. So I am gonna get a set of rear knuckles from a newer model and see where that leaves me.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 07-07-2016, 06:52 PM   #22
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got the setup off an 09 vibe. While it looks tempting in the exploded parts diagrams, it's clearly not a match in any way. I think I'm going to keep the Yaris bits but return the Vibe hubs and splash guards. The calipers look like they might be promising, as they don't have an internal drum parking brake.
Old 09-07-2021, 11:08 PM   #23
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Here's everything you need for a complete bolt up rear disc brake conversion.
Rr Axle Beam 42110-0D181
R Rr Brake Caliper 47830-52090/47830-52161
L Rr Brake Caliper 47850-52090/47850-52161
Rr Caliper Sliding Pin Bolts 90015-AA102
Rr Caliper Sliding Pins 47835-12150
Rr Caliper Bkt R/L 47821-12150 (11-14 CT200)
Rr Caliper Bkt Bolt 90105-10404
Rr Brake Rotors 42431-0D110
Rr Brake Rotor Shields 47803-52010/47804-52010
Rr Brake Pads 04466-52130
Rr Brake Pad Shim Kit 04946-52080
Rr Brake Pad Fitting Kit 04948-52040
Rr Brake Hoses 90947-T2033
Rh Parking Brake Cable 46420-0D130
Lh Parking Brake Cable 46430-0D130
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 09-08-2021, 02:54 AM   #24
rayfloyd170
Drives: Yaris 2016 1.3 Manual
OT: Been a while, nice to hear from the Grand Master :)
Anyway, excited to know the updated mileage your yaris have at the moment
Godspeed!
rayfloyd170 is offline   Reply With Quote
Old 09-29-2023, 11:54 AM   #25
Yarisguy69
Drives: 2011 black yaris
does the toyota c-hr disc fit the 2011 yaris
Yarisguy69 is offline   Reply With Quote
Old 01-22-2024, 04:36 PM   #26
tayxas
Drives: 2008 dailycross beater on B14s
C-HR is 5 lug
2011 Yaris is 4 lug
tayxas is offline   Reply With Quote
DIY - Standing rear wiper for hatchback sex DIY / Maintenance / Service 42 10-17-2018 07:32 AM
Runstop rear brake conversion parts computerlove87 Performance Modifications 2 03-30-2016 09:34 AM
DIY Sedan rear bumper removal? gabriel2012 DIY / Maintenance / Service 0 11-07-2014 07:42 PM
Vitz Rear Wheel conversion Asif Cosmetic Modifications (Exterior/Interior) 18 01-09-2013 10:47 AM
