Old 06-05-2016, 08:52 PM   #2
jcboy
Drives: Sedan 07
Yeah, when troubleshooting you should always try with the cheapest approach first.
If it helps, you should never "recharge" your AC. Why? Because AC systems are closed loop, meaning the refrigerant (freon) should be contained forever in an ideal world.
In the real world, the moment your AC goes out (the cooling doesnt work), it means there's something wrong with it--either a compressor not doing it's job, or you have not enough refrigerant.
If they say it lacks refrigerant, then it means you have a leak somewhere--be it on your evaporator, condenser, drier or somewhere in the line/piping/tubing.
And yeah, if there is too low of refrigerant pressure, the compressor might not turn on--so "recharging" the freon is a troubleshooting step for AC problems rather than a solution.
Hope this helps.
Does DFCO still work when using cruise control? rtom Fuel Economy Forum 10 01-20-2010 12:26 AM
Need Truth About Warranty Work . . . woof DIY / Maintenance / Service 17 12-12-2009 03:39 PM
Got hit at work today, lady drove off. Prohibit General Yaris / Vitz Discussion 41 11-04-2009 11:38 PM
Drove home from work with a damaged belt and... AznGouki DIY / Maintenance / Service 44 09-07-2009 02:08 AM
Idea I had, but I can't figure a way to make it work... kac Cosmetic Modifications (Exterior/Interior) 4 08-08-2009 09:17 PM
