Drives: yaris Join Date: Feb 2011
Hi guys !!!
please help me up my 2007 yaris has both driver and passanger airbags light on and also passanger seat belt light on. I allready disconect battery for 30 minutes and nothing. please help me over |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you gotta go to dealer or to a shop that has the higher end scanners like snapon modis or OTC with the import and airbag kits. you can't just go get a cheapo scanner and delete it
you may also be able to get away with removing the terminals from battery and attaching them together for about 10 min. DO NOT TOUCH TERMINALS TOGETHER IF THEY STILL HOOKED UP> |
See this post for directions on how to read and then clear the SRS DTCs using just a jumper between two pins of the OBD port:
http://www.yarisworld.com/forums/sho...d=1#post557473
Drives: Aygo Join Date: Jul 2016
Does this procedure work on a 2007 Aygo? The car has been powerlees for some time and now I put in a new batteri. But the airbag light keeps flashing.
It should work on the Aygo as well.
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| How do you reset the TIRE PRESSURE WARNING LIGHT | penny09 | DIY / Maintenance / Service | 3 | 09-26-2010 02:53 AM |
| How do I reset maintenance light? | Snake | DIY / Maintenance / Service | 10 | 06-04-2010 12:57 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| "Airbag" center console light on 07 Sedan with side airbags | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 11-10-2006 06:10 PM |
