Old 07-31-2016, 05:56 PM   #22
Swing
Drives: Yaris P1, MR2 mk1, 4x4 Hiace
Originally Posted by CoryM View Post
Actually from the parts diagrams it looks like the clutch is in the rear diff. Look up "Transfer assembly" here:
http://www.megazip.net/zapchasti-dly...5-ahpgk-423043
T-case is just a simple ring and pinion, no center diff. All the slippage happens in the "Coupling assembly" which I assume is either a viscous clutch, or a tiny multi-disc clutch. Could be either or both if it has a lockup.
Where can I find this Coupling assembly in the parts system?
If you lookup "Transfer assembly" then you just get the outside of the transfer case. (which is indeed only ring and pinion, no diff)
Swing is offline   Reply With Quote
New Member with a Rarer Vitz / Yaris in JPN Metrella Asia 1 04-28-2016 11:38 AM
Buying a Vitz or a Yaris David1991 Third Gen Yaris General Discussion 2 07-23-2015 08:41 AM
yaris and vitz the same? toddbhowman New YARIS Purchase Forum 12 02-23-2007 01:45 PM
