Originally Posted by Swing
Where can I find this Coupling assembly in the parts system?
If you lookup "Transfer assembly" then you just get the outside of the transfer case. (which is indeed only ring and pinion, no diff)
The rear diff is: 41301-52100, which is the same rear diff as the 2008 US market RAV4. Even the entire assembly (41110-52010) is identical to the 08 Rav4.
The coupling for the RAV4 is different though. The RAV4 used an electromagnetic coupler allowing the rear drive to be disengaged. The NCP95 Vitz used a viscous coupler with no option for disengagement.
