Old 09-13-2016, 12:31 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by DevilzMafia View Post
I was driving the other day and right when I put my foot on the brakes, it felt like the ABS module was stopping me from applying normal brakes, it got slightly softer than usual, and one could hear some motorized sounds (probably from the ABS pump).This all happened for a few seconds, then braking went back to normal, except that the ABS light came on.
Now I've looked over the forums and the internet a lot before posting this thread.
So here are my two questions, is it even possible to find a new ABS module/actuator from the market? All I see are used parts or people selling from scrap on ebay.
Second, how on earth should I disable the ABS check light? Using a scantool, resetting the battery, and removing the 50A & 30A fuses didn't work.
I would scan it first could just be abs sensor that went in one of the wheels and if so it will put the car in normal brake mode also one can not turn off the abs light.
So before you go crazy spending money on parts you dont need have it scanned .
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
2009 Yaris airbag light staying on #30 DIY / Maintenance / Service 7 08-27-2015 05:57 AM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
Brake & ABS Light On JeffRapp DIY / Maintenance / Service 3 01-04-2013 11:10 PM
2006-2011 Yaris Liftback Intermittent Rear Wipe Module CTScott Items for Sale by private party 5 12-28-2011 11:28 AM
