Old 10-24-2016, 02:17 AM   #1
SAQ
Drives: Yaris 2015
Trouble in locating "Tach Wire"
Please assist into locating Tech Wire.
I am installing remote starter on my Yaris 2015. Cross wiring chart says, "wire (RDA); connector (D143 White 30); pin 16; wire color (Pink); polarity (DATA); located at (Body ECU next to dash fuse box)" Is this called Tach as well or something else.
Remote error code is referring to "Tach sensing issue". Thanks.
SAQ is offline   Reply With Quote
Old 10-27-2016, 09:54 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It's a black wire on the OBD connector. I forget if there's more than one but I think its in the middle somewhere.
Old 10-27-2016, 11:53 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Tachometer OBDII multimeter frequency revolutions per minute RPM
There's threads and pictures here showing the RPM input on one of the 4 end sockets of the 2-row OBDII connector. #9? I'm getting good two pulse/rev input there for the frequency setting on a multimeter tucked standing up into the little pull-bin next to the drivers window...multiply by 30 for RPM.
Trouble Code P2121 1nz DIY / Maintenance / Service 9 09-02-2024 07:59 AM
2010 Yaris Sedan - TROUBLE W/ TROUBLE CODES Iceman6969 DIY / Maintenance / Service 4 07-25-2014 08:35 AM
Trouble finding correct mirror glass Daz... DIY / Maintenance / Service 0 11-26-2011 10:03 AM
Alternator Trouble butter DIY / Maintenance / Service 1 08-10-2010 03:39 PM
Trouble locating tach wire-Help!! GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 2 08-03-2009 11:59 AM
