Old 08-03-2009, 11:01 AM   #1
GreenSpeed
Drives: '08 Yaris LB
Trouble locating tach wire-Help!!
I have been following the different tach intall guides to locate the greenish-blue wire in Pin 15 of the Data Link Connector (OBD2) directly below the fusebox. The problem is that the furthest left wire in my OBD2 plug is a light orange wire and nothing actually appears to be in the Pin 15 area.
There is a light greenish blue wire that is in the middle area of the plug and I actually connected my tach to that, but got no reading.
Would it have something to do with my Yaris not being pre-wired for a tach?
Thanks for your help!
GreenSpeed is offline   Reply With Quote
Old 08-03-2009, 11:53 AM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
The light orange wire is correct for the 08 LB. See below.
Old 08-03-2009, 11:59 AM   #3
GreenSpeed
Thanks so much!!!
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
09' tach wire different? [pic] Taiyaki Cosmetic Modifications (Exterior/Interior) 18 01-24-2011 01:30 PM
Tach Illumination wire Liu997 DIY / Maintenance / Service 6 05-29-2009 11:11 AM
Tach ECU wire, auto Liu997 DIY / Maintenance / Service 8 05-06-2009 01:44 PM
Dimmer Wire for Tach mrrock DIY / Maintenance / Service 7 11-29-2006 07:18 PM
