Old 06-22-2017, 08:35 PM   #3
zoidberg444
zoidberg444's Avatar
Originally Posted by NYC-SE View Post
Anything is possible with enough time and money. As someone with a deficit of both I guess I have to ask why?
Having everything on the wrong side makes it difficult without a passenger. Its my experience when i take mine over to Europe. They drive on the wrong side of the road just like you guys do in the states. 😂
On a serious note i'm sure it could be done. You would need a dash pulled out of a JAP/UK/AUS market Yaris and while i'm not an expert you would also need a steering rack because the steering shaft connector would be on the wrong side. Not to mention you would need to swap the clutch and brake master cylinders and lines over to the other side and relocate the accelerator and the cables for it. I'm not familiar with the LHD Yaris but i might assume that the body module which is behind the glove box on the passenger side was moved over to the wrong passenger side for LHD and would need to be moved over to the old drivers side? Also you would need to swap chairs because the passenger seat has less adjustment than the drivers seat.
Sent from my SM-G930F using Tapatalk
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Trying to find part numbers for yaris sedan 2011 front bumper conversion YarisSedan Cosmetic Modifications (Exterior/Interior) 7 11-30-2014 07:39 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
OEM Toyota Yaris / Vitz RS conversion botchilah Cosmetic Modifications (Exterior/Interior) 4 08-06-2009 02:47 AM
