Old 09-01-2017, 09:01 PM   #12
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Originally Posted by Kalispel View Post
Considering how bad most roads seem to be today (who needs infrastructure, after all), I don't think I would want to drive/ride on anything lower-profile that XXX/50 series tires - which is what the Yaris happens to need with 16" wheels to maintain factory specifications for speedometer accuracy, etc. 16" wheels are also the perfect look with the Yaris using the factory suspension setup. If you don't mind throwing the speedometer off a wee-bit (~3 MPH I think), you could even run XXX/55 series tires with 16" for a better ride & less fender gap. I don't think that 17"+ wheels looks right/good on the Yaris without lowering springs (1.5" drop). Even the 16" on the SE could have used a 0.75" more factory drop, instead of what it was given as default.
i can run 16" you just need x6 to be useful
Sent from my LG-H918 using Tapatalk
DarkShadowFox is offline   Reply With Quote
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
FS: Yaris RS Alloy wheels W/Tires & Lugs mr.white_hb Items for Sale by private party 23 03-30-2009 10:40 PM
