Old 09-02-2017, 11:37 PM   #10
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
the cars running pretty lean...a lot of air and less fuel (from the gauge)
or it is maybe its hot af here? anyways ill get 330c injectors(E85), regulators and redyno...give me about a week or two
Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Granite State Dyno & Tune Open House fnkngrv New England 0 03-18-2014 11:35 AM
N/A performance tune yaris2010RS Performance Modifications 3 12-13-2012 01:33 AM
Tiamat 10 July 12 Dyno Tune and Results - Stock motor top speed found fnkngrv Forced Induction Forum 4 10-06-2012 11:00 PM
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
