Old 09-13-2017, 06:08 AM   #1
komichal
Red face Wires for rear speakers
Greetings!
I have 2007 Yaris II 5-door hatchback.
Music from the radio was too quiet on the back seats and I found out that I have no speakers in the rear doors installed.
The hole for the speaker is there in the door but it has never been used, it is still covered by the plastic.
Buying and mounting the speakers is simple but how about the wiring? At first notice I was not able to see a cable that I would be able to connect the speakers to. But maybe it is somewhere well hidden?
Or do I need to do the wiring on my own? That is something that will probably completely stop me from installing the speakers.
Thank you for sharing your experience.
Old 09-13-2017, 11:03 AM   #2
miiser
miiser's Avatar
Drives: yaris 2009
You have to wire them by ur own. I will do it too some time in the feature. To make things simpler u can use the front wiring of the speakers and extend it to the back so you don't have to take apart the headunit from the dash
miiser is offline   Reply With Quote
Old 09-13-2017, 02:56 PM   #3
komichal
Ha, I have mounted out the car radio to check the wiring and according to the electrical sheet the rear speaker wires are connected! This means they must be leading somewhere. Maybe they are in the door after all, just well hidden somewhere... I probably need to take a second look or start a detective tracing of the wires from the radio to find out where they end...
Old 09-13-2017, 04:15 PM   #4
miiser
miiser's Avatar
Drives: yaris 2009
Check behind front seatbelt plastic covers.
I saw somewhere that there are ready wires that you can lead in the doors. I just never had the time to check it out by myself
Old 09-13-2017, 04:16 PM   #5
miiser
miiser's Avatar
Drives: yaris 2009
This should be the right wiring map
Old 09-14-2017, 12:06 AM   #6
komichal
Thanks miiser, I will check it and take some photos to share. The wiring map you provided matches the one I have so it seems like a good start. :-)
Old 09-14-2017, 10:18 AM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
The speaker wires should end in the kick panel on either side of the car. Normally, you just need to extend those to the rear doors, unless Toyota decided to make a separate harness from the radio, which I highly doubt.
Old 09-14-2017, 10:27 AM   #8
miiser
miiser's Avatar
Drives: yaris 2009
You are welcome. Hope there are in fact ready wires behind seatbelt's panel. I will wait your response
Old 09-14-2017, 02:26 PM   #9
komichal
Hi IllusionX, what do you mean by "Kick panel"?
I am not English-native and I thought that kick panel is the part close to the driver foot where his foot can rest when it is not operating with the clutch pedal.
But from your response I think you actually mean something different...?
Thank you and sorry for introducing even linguistic issues... :D
Old 09-14-2017, 02:50 PM   #10
IllusionX
More or less yes what you describe. It's a bit forward, where it meets the door when closed.
Here is a picture I took from the internet.
Door speaker wires should be connected in that area to the head unit (radio).
Old 09-14-2017, 03:28 PM   #11
Impact
Drives: 200 Vitz RS / 1998 Evo V
cool
Impact is offline   Reply With Quote
Old 09-15-2017, 06:16 AM   #12
komichal
I have just realized that there is no "hose" between the car body and the door to push the wires through.
Well - there is a hose but there is also a connector closing it so it is not easily accessible.
Anyway - first I need to find the wires somewhere. Hopefully I will be able to recognize them...
Old 09-15-2017, 08:50 AM   #13
miiser
miiser's Avatar
Drives: yaris 2009
No luck till now?
Old 09-15-2017, 02:59 PM   #14
komichal
I do not have a garage to park my car in so I need to wait till it stops raining and is still daylight at the same time... �� I did just some very quick checks on the parking lot, tearing off covers to see if there is anything obvious but no luck. All cables are winded in black tape. Need to take it off to see if some wires are there terminated...
Old 09-18-2017, 01:44 AM   #15
miiser
miiser's Avatar
Drives: yaris 2009
I am waiting to hear from you when you finally do it
Old 10-09-2017, 02:29 AM   #16
komichal
I am finally back here.
The good thing is that I was able to trace down the rear speaker wires.
I removed the front seatbelt plastic covers and the wires are there. They lead up to the connector opposite to the rubber hose connecting the body and the door. So this is good (but I was unable to detach the connector though so I do not now if there are speaker wires in the rubber hose as well or if I have reached the end of the line).
What is bad is that when I removed the rear door panel and peeked in through the speaker hole I was only able to see the wires for door lock but nothing else. It may not seem that way on the picture but there is so little space in there that I was not even able to remove the black tape inside the door to see whether there is actually a connector or something else that would indicate that the speaker wires are there or not.
Probably as the next step I need to remove that rubber hose somehow to see what is inside. But it was already dark so it will be the next part of the story, if I ever dare to do it.
Pictures:
https://ibb.co/eUs0Jw
https://ibb.co/nDNNWG
Old 11-07-2017, 10:28 AM   #17
miiser
miiser's Avatar
Drives: yaris 2009
Pictures:
How did you remove this panel behind seatbelt?
Also is it easy to remove the back door panel?
Old 11-07-2017, 01:51 PM   #18
komichal
The panel behind the seatbelt went more or less fine. You just need to pull up both plastic door thresholds and then I gave a proper tug to the panel - and it went off. Not sure if this is the right and official way but it worked and no clip was broken.
Removing the back door panel is easy too. You just need to
- remove the window handle (there is a pin behind the handle sou you either need to use a proper tool or a rag trick or two sharp screwdrivers (my case) to remove the pin (it shoots away!) - then the handle goes off
- remove the screw behind the "open door" handle
- remove the screw inside the small pot in the door "hand handle" (hidden behing a cap, removable by a flat screwdriver)
Once the window handle and the two bolts are gone, you just need to grab the panel in the corner where the speaker is supposed to be and tug firmly. The panel gets partly off and you just need to go around and pull it off all around. Once done, slide your hand in and remove the two metal wires from the door handle (just peek in to see how they are connected, it is a simple mechanical connection, no tool necessary).
Once you are in you will see a clear plastic coating all around the door, glued to the door by a black messy stuff. Heat that black stuff a bit and the plastic can be peeled off eventually. But in my case, I just cut a hole in it and once I was done I taped it together using a silver duct tape. It would probably deserve a better solution but at that moment I was just pissed off that there are no wires in the door so I wanted to put everything back together as quickly as possible.
radio, speakers, wiring, yaris
Ultimate Turbo Pre-Install Guide Focus_Sh1ft Forced Induction Forum 7 09-14-2017 03:28 PM
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
Replacing Speakers + Upgrading System ANONGMUSIC In Car Entertainment + Electronics (audio / video / alarm) 7 03-31-2012 05:45 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
No Sound Rear Speakers Help AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 10 05-05-2011 03:41 AM
