![]() Drives: 2009 Yaris sedan Join Date: Nov 2016
Changing the fuel filter
Hi all,
I'm trying to find a good quality generic fuel filter for a 2009 Toyota Yaris base 1.5. But after searching I could not to get it, Can anyone tell me where I can get a exact fuel filter like mine or if I can't do it? ![]() Do I have any cheap options? ![]() I tried the autoparts stores and they tell me they only sell the fuel filter as the whole fuel pump for $300.00. I can't shell out $300.00 every 100,000 miles just to change out the fuel filter. Can anyone please offer advice if there is that one fuel filter sold seperately like mine. What brand? Thank you for any help offered. |
Is there any particular reason why you want to change it? Showing symptoms of being clogged, or you just feel like it should be a maintenance item? Unless some serious crap got into your tank, these filters are pretty much in there for life. Very few have needed to undertake the horrendous task of replacing one on thee cars.
Agree there is no requirement to change the filter. Nor does Toyota sell the filter without the pump .
It's supposed to be changed only if its clogged.
The filter is essentially part of the pump unit. It isn't a service item.
Drives: Toyota yaris 2000 SCP 10 Join Date: Nov 2014
I am using Toyota Vitz 1.0L YOM 2000 / service chart shows to change the fuel filter ( after Fifteen Years) I havent even inspect it. Do I really need to change the Fuel Filter with the Pump
![]() Drives: 2006 and 2013 Join Date: Apr 2013
I replaced mine at about 80,000kms. In my service book it is listed as a replacement item every 80,000kms.
I just used an ebay one and it I am now up to 150,000kms. |
![]() Drives: 2008 BLACK YARIS Join Date: Sep 2017
I picked up a load of crappy petrol a while ago.
The beast ran like a sloppy lawnmower. The pulled the tank and flushed the fuel lines. I asked about the filter and if I needed to change it. They said that they replaced it (its a big job) but they also said Id not have to change it again unless it clogged. Apparently, while the vehicle is running, leave it alone. This from a Toyota service centre |
| HELP: Swings but does not start after fuel filter replaced | REV 2 11 | DIY / Maintenance / Service | 12 | 08-19-2013 02:38 PM |
| Fuel Filter | caveatipse | DIY / Maintenance / Service | 27 | 12-28-2012 10:45 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Replacing fuel filter | duke_afterdeath | Middle East | 28 | 07-12-2010 05:26 AM |
| Fuel Filter | abbeyaris | General Yaris / Vitz Discussion | 35 | 03-22-2009 12:40 PM |
