#22 | |
I mentioned that I had watched a video on shrinking the tint on the outside of the window. It demonstrated how to create fingers by bringing the outer edges towards each other slightly, then heating and smoothing down the fingers. Well, this cheap film didn't seem as pliable as the quality film they used. It was reluctant to create fingers and sort of bunched up a bit, even though I had lots of slip solution on both sides. So the film, again, was a touch large for the window. The interplay of cheap film, me rushing, my inexperience and not the best conditions resulted in a failure. I do have the free replacement kit coming, so I will try again but if that fails, I'm defintiely off to the shop. Thanks
| DIY - OEM Power Window Conversion | CTScott | DIY / Maintenance / Service | 29 | 10-27-2024 11:02 PM |
| Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 10:03 AM |
| DIY: How to remove window tint | cali yaris | DIY / Maintenance / Service | 4 | 07-30-2012 02:18 AM |
| Replacing my aftermarket window tint. | Herbicidal | Cosmetic Modifications (Exterior/Interior) | 11 | 07-18-2010 11:56 PM |
| DIY Window Tint films from Walmart | Dec24th | Cosmetic Modifications (Exterior/Interior) | 14 | 01-15-2010 12:28 PM |
