Old 01-23-2018, 04:56 PM   #15
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
Originally Posted by esse10 View Post
Using anti-sieze does not change the torque value. It might make the threads go a little farther in because of the lubrication. 10 foot pounds is still 10 foot pounds.
example; if you torque a nut to 10 foot pounds and it stops at 12 oclock on the scale, if you lube the threads and torque the exact same nut then it will stop at around 2 oclock on the scale, but it's still 10 foot pounds.
It's minimal difference I've used a little anti-sieze since day one with no issues.
NGK disagrees with you: Anti-seize compound can act as a lubricant altering torque values up to 20 percent, increasing the risk of spark plug thread breakage. You and I are not qualified to contest their claim.
alanwagen is offline   Reply With Quote
Best spark plugs for Toyota Yaris Verso ? Jesper M DIY / Maintenance / Service 2 09-29-2016 11:00 PM
Changed Spark Plugs and Now Car Won't Start VegeLasagna DIY / Maintenance / Service 20 06-24-2016 10:36 PM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
