Old 05-24-2018, 10:41 PM   #2
tmontague
tmontague's Avatar
Yes, 5mm is as large as you would safely want to go outside of getting the studs to match the spacer thickness.
Ie: either 5mm spacer w/ oe size studs of 10mm extra long studs with 15mm spacers
Front wheel well plastic question? Pinchlite Cosmetic Modifications (Exterior/Interior) 19 03-28-2017 08:10 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Well Question gwasabi Cosmetic Modifications (Exterior/Interior) 3 04-15-2009 12:09 PM
Wheel well Question Repost gwasabi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 04-13-2009 07:17 PM
Wheel Care Question - Polish coming off? Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-25-2007 05:49 PM
