#37 |
![]() ![]() Drives: |Mr2 Join Date: Feb 2018
D'OH !
pretty sure that i got cast instead of forged. anyone know how to tell? what is the weight of a factory cast piston, this one is 201gm~ |
#38 |
new vs stock(has the rod i haven't removed yet) in case you couldn't tell
pretty sure not forged.... but i'll at least balance them and use them , i mean. i paid for them
#39 |
forged with spraypaint.
#40 |
#41 |
i have to say , one of my favorite parts of globalization, is that we can find things that 20yrs ago would never have been possible.
found a cam manufacturer 9.5mm lift, and drop in , so if anyone wants to check it out, only 450$ FOR THE PAIR https://www.facebook.com/BQ-X-SKTK-P...7524227419480/ |
#42 |
#43 |
so far, from what i can tell.
if i go with toyota factory bearings, for the crank and rods, those are one of the most expensive components. and the number code etc... f**k it, i'll go for standard bearings off ebay |
#44 |
why dont you just go with a forged aftermarket crank and rods????
#45 |
i do have forged rods, but the crank is the stock piece.
toyota oem bearings, for the crank., was going to be 250ish and 6 week wait, from japan |
#46 |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
The 1NZ is common enough there must be decent quality aftermarket support for bearings, etc.. A quick RockAuto search shows Mahle/Celvite set of main bearings for ~$50, ~$40 for con. rod set - have to buy single pairs for Mahle/Clevite. About half the cost if you go with EngineTech or ITM stuff.
Just FYI.. When you're throwing boost at it, at least you'll have a decent brand vs. super cheap eBay - although who knows, you may find a great deal on a good brand via eBay too! ![]() Looking forward to the build! -- Adam |
#47 |
this is the last purchase for me, ok, latest one.
https://ebay.com/itm/MAIN-BIG-END-BE...72.m2749.l2649 but i meant the number codes on toyota cranks and mains, 1-5 for the crank and similar on the block. i figured the difference in bore on the main journal was .0005 on the main between numbers so i hope (fingers crossed) that i can only notice low oil pressure. .. if not , i'll get actual toyota bearing next round (and forged pistons too) |
#48 |
well, got my aem fic 6 in the mail.
pillaged a factory ecu from the wrecker to build my own harness between car and ecu. turns out , can re-use the factory mr2 wires for the 1nz, so reusing the factory harness is going to make my task much easier... install the fic on my 1zz, learn to tune etc, and then when i put in my turbo 1nz, i'm less likely to destroy it |
#49 | |
2ZR swap. DO IT! Ask how!
#50 |
some photos.
1.ported intake 2,3,4.ported/softened combustion chamber (hopefully lower compression a point or two) 5.notched block for rod clearance 6. repinning connection to make patch harness ps, wish these pics were even bigger, you could count the atoms.. sigh |
#51 |
well... sh**
i talked to the machine shop and the pistons and rods i have are not going to work together. on stock rods the pistons would work fine... but not the rods i am using . upside, ordered weisco forged pistons, rings, pins and clips for a decent price ($800cdn) 9:1 compression, so i can at least run 15+ lbs, but takes the budget aspect out of my build... |
#52 | |
#53 |
Sorry to hear they didn't match up for ya...
^ I think he means by going with the Wiseco piston setup those will pair with the CXRacing forged rods (vs. Wiseco and stock rods). Two steps forward and one step back is still going forward - albeit more slowly.. lol. Keep at it man, can't wait to see the results. -- Adam |
#54 |
upside, i can finish porting my cylinder head
reassemble over the fall/winter and then play with the tuning (fic6) turbo size is my next one- likely t28 size so i don't have terrible lag |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Quantum Technology Hydrogen 1NZ Turbo Kit GT1241 | JustDidIt | Items for Sale by private party | 13 | 08-31-2018 03:07 PM |
| Turbo Echo - The False Prophet | EchoLaQua | Forced Induction Forum | 12 | 03-14-2018 12:58 PM |
| 1nz turbo (england) | 1nz_tommy | Forced Induction Forum | 1 | 10-17-2014 08:06 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
