#19 | |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
If you would actually use a torque wrench to properly torque the lugs to 103Nm and use anti-seize or other water resistant lubricant (I use white lithium grease), you will see that the stock lug nut wrench is just the right length to achieve similar specified torque when tightening and long enough to break them loose, by anyone. Short maths show that properly torqued and lubed threads won't require much more torque to break loose than it was required when you installed them. I use a torque wrench the same length as the stock lug wrench and it's a breeze to do. Using an impact wrench on chrome hardware is not recommended, that's why a lot of people both over torque the lug nuts, without any lubing, damaging the threads, and chip off the chrome plating, then complain how rusty and stuck the lug nuts are. |
#20 |
Easier said.... when you have your wheels removed for a state (safety) inspection and for tire rotations
It goes goes without saying that lug nuts are removed and tightened with a impact wrench.... and no lube is ever applied. However, this Wednesday my Yaris will be inspected and the tires will be rotated...... yearly ritual . When I get the car home, I will remove the stock lugs and install the new ones. Be assured that I will oil the threads and apply the proper torque. In any event, a 4-way lug wrench always makes things easier.
#21 |
Hey, if it's for safety inspection, you have all the right to ask the mechanic to re-install the wheels per Toyota specifications, aka properly lubed and torqued ;)
#22 |
If.....If......
There is an old saying.. .. "If the queen had balls, she would be the king" ![]() In other words, "If " can't always have relevance and just proposes the possibility of relevance. Also, one can asks for anything but, that doesn't mean that they will get it.
#23 |
RedRide, your car looks very nice. Like that colour. The stock black steel wheels with trim rings and centre cap is great! Toyota should have done that on this car instead of the plastic wheel covers.
#24 |
Just a Gaijin
When you are using anti seize or any other lube on the lugs nuts, you need to know that this 103Nm manufacture torque rating is always a dry rating.
So if i was you i'd stay away from experiments like this if you are not aware of what you are doing and just mount your wheels without any lube and the dry torque rating. Watch this video. He explains it pretty good. https://www.youtube.com/watch?v=X3ndeXiZUeM Last edited by DiCaprio; 06-13-2017 at 09:06 AM. |
#25 | |
Some seem to need the last word.on this... So, I will l let them have it . ![]() I will just say (after all the hyperbole subsides) that they are only lug nuts and not some bolt on the space station.
#26 |
I always found that color interesting, and have only seen one or two in person, but from far away.
The next time you do a full detail, you should polish the paint. I personally like Meguiar's Deep Crystal Polish. It'll bring out even more depth in your carmine red color! It shifted my blazing blue to look like it had some green in it (hard to explain, but the color reminded me of bayside blue on the Nissan Skylines). |
#27 |
Well, what a difference a year made!
The clear coat is now pealing and blistering almost everywhere, except for the front and rear bumpers. It's a disaster! It's now in a body shop right across the road from my apartment complex for basically a full repaint. It's not going to be cheap but my '09 only has about 16,500 miles on it so, it is well worth spending some cash on it. |
#28 |
Hopefully the respray lasts a long time! Keep it clean and protected (waxed) - hopefully that helps
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 03:13 AM |
