Old 10-17-2018, 07:29 PM   #19
YodaBird
Drives: Gray
Originally Posted by DarkShadowFox View Post
my brain hurts.
It's better to have clarification then simply agreeing to something that may not be right, right.
YodaBird is offline   Reply With Quote
Old 10-20-2018, 05:03 PM   #20
DarkShadowFox
its very expensive to change the rear to discs too, unless you want to clean up stuff from a salvager. See: Rare.
its going to cost in the thousands.
also the discs suck during hard driving such as on the highway or for quick emergency stops :U
Old 10-20-2018, 08:39 PM   #21
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Say what?
NYC-SE is online now   Reply With Quote
Old 10-21-2018, 02:15 PM   #22
DarkShadowFox
Originally Posted by NYC-SE View Post
Say what?
yeah unlike most people i drive my yaris like a car. the rear discs lose braking power quickly and overheat easily when you drive alot like i do.
Old 10-21-2018, 02:18 PM   #23
YodaBird
Drives: Gray
Your rear discs having loose breaking power quickly and overheat.
Old 10-21-2018, 02:49 PM   #24
Why has a random discussion about rear discs shown up in a thread seeking identification of a drum brake part?
Old 10-21-2018, 03:18 PM   #25
DarkShadowFox
because its drum brakes.
Old 10-21-2018, 03:19 PM   #26
DarkShadowFox
http://yarisworld.com/forums/showthr...076#post818076
Old 10-22-2018, 02:16 AM   #27
miiser
miiser's Avatar
Drives: yaris 2009
Wheel Plate only on Rear ?
I never stop learning
But seriously, that’s so wrong. Drum brakes have zero like absolutely zero heat dissipation. It’s an enclosed system and the only thing that it’s good, better than disks, is for handbrake usage. Nothing else.
I found it offensive to see manufacters cheap out and still using this system in modern cars. The cost of manufacting a car with full disks rather than disks and drums is almost the same. But I guess they make more money by making this an extra option. And if you want to make the conversion after you buy the car then good luck. You have to change even the handbrake inside the cabin and it cost way more. I don’t know why full disk brakes aren’t mended by the law in 2018 like so many other safety futures when even the slowest modern production car can easily archive 80mph
miiser is offline   Reply With Quote
Old 10-22-2018, 12:14 PM   #28
enviri
enviri's Avatar
Drives: 2010 Yaris
a swap would cost thousands if you are bent in buyin everything retail off a stealership. 1000 bucks is usually plenty to buy a whole used axle and direct swap it in. The few people i know that did an axle swap here in USA paid farr less than "thousands". This applies to being shipped to usa from japan or the local junkers in usa. The handbrake change is just swapping of cables, if the axle is complete (often it is)
Old 10-23-2018, 10:58 AM   #29
miiser
miiser's Avatar
Drives: yaris 2009
Still, it cost a lot.
Old 10-23-2018, 11:31 AM   #30
enviri
enviri's Avatar
Drives: 2010 Yaris
should have optioned it from the dealer :P
Old 10-23-2018, 03:03 PM   #31
DarkShadowFox
i can do that work myself, i have the GSIC manual, so it would be 405 dollars plus some pizza and beer to have someone do a disc swap. but then your also looking at discs and other BS. so 1000 before labor.
Old 10-23-2018, 03:03 PM   #32
DarkShadowFox
cannot option that from the dealer. its an SE option only. i asked.
Old 10-24-2018, 01:04 PM   #33
enviri
enviri's Avatar
Drives: 2010 Yaris
you took that too literally, since american yaris dont really have any options except for some crap like a trunk net, SE would be the 'option' you could have taken. yaris in europe has a whole ton of trims and options i just put it all in an umbrella term.
Old 10-24-2018, 05:06 PM   #34
DarkShadowFox
if you cant get a 3door or an L with disc brakes when a ford used to come standard with discbrakes and just as safe safety features whats the exuse for shelling out nearly 19-20k for a new yaris with disc brakes and the rest that go for 15- 18 with DRUMS.
Rear wheel bearing LeetViet DIY / Maintenance / Service 1 08-29-2012 07:41 PM
JDM leather wheel OR JDM Vitz RS rear bumper??? evo165 Cosmetic Modifications (Exterior/Interior) 31 02-14-2012 08:26 PM
wtb Rear Sway Bar and Wheel Spacers TickleTimeTim Willing to Buy by private party 5 05-13-2011 12:16 AM
