Old 08-29-2012, 06:41 PM   #1
LeetViet
Drives: 07 Yaris 4DR
Rear wheel bearing
How do I know if a rear wheel bearing needs to be replaced?
A mechanic said he took my car for a test ride, and heard a noise from the rear wheel, but I don't hear anything! I will be taking my car to another shop for a second opinion.
LeetViet is offline   Reply With Quote
Old 08-29-2012, 07:41 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
Raise the car so a rear wheel is off the ground and then try moving the top of the tire in and out. If a bearing is going there should be some unwanted play/looseness. Lower and repeat at the other side.
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
