#11 | ||
Most of us were only able to do this swap because of the help of others, and I'm glad we were all able to help you out. Your trans code should clear once you connect and ground the proper wires. Definitely ground pin 9 that Tom mentioned, it is correct as per the ewd. Enjoy a weekend of hooning around a 2zr swapped Yaris!
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 10:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 10:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
