Old 12-04-2018, 06:16 PM   #4
atomic_hoji
Drives: 2018 Yaris SE 5MT
There are two spots on each side along the pinch weld that are meant for supporting the vehicle - as Trevor noted, there's a concern about rolling them if you're not careful. They are intended for jacking/lifting the Yaris though and it's what a shop will use to lift the care on a hoist.
The by-the-manual jacking point on the Yaris is that big bolt in the center of the sub-frame, directly behind the transmission - lifts the whole front end up. You need a fairly long-handled jack to slide way back in under there. The owner's manual has a basic diagram of the front and rear jack points if I recall, but that picture you posted shows the bolt location clearly. Rear has a noticeable 'stub' just in behind the rear bumper, to the left of the exhaust if you're looking at the rear of the car, sticking down - again, a jack under this point lifts the whole back-end of the car.
-- Adam
atomic_hoji is offline   Reply With Quote
Is a 2006 Yaris coupe different from a 2007 Yaris coupe? fuzzybabybunny General Yaris / Vitz Discussion 0 02-25-2016 07:09 PM
Are there alternative jack stand spots? (08 Yaris) Silverkarn DIY / Maintenance / Service 4 11-10-2015 06:33 AM
Does the Toyota Yaris come with a jack? RMcG Third Gen Yaris General Discussion 7 08-20-2015 11:03 AM
