Old 12-30-2018, 09:58 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Here is a snippet from the internet. Not sure how reliable it is and compatibility would have to be confirmed by wiring diagrams. Check out this link.
https://blog.toyota.co.uk/toyota-yaris-cruise-control
I'm not sure if your car used the Takata airbag and if yours was recalled and the airbag replaced. Just as an FYI, after I had my airbag recalled, my cruise control (that I added myself) stopped working. The wiring in the replacement clockspring did not support cruise control. I had to source another clockspring with the same part number as my original and swap it for the recalled one. Then, my cruise worked again.
My experience:
http://www.yarisworld.com/forums/sho...ht=clockspring
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
