Old 12-30-2018, 01:29 PM   #2
tmontague
tmontague's Avatar
The hoses are not too had to access once the underbelly pan is removed. Find an aftermarket set for cheaper and swap them in if needed. The potential issue will be if any bolts are corroded.
I swapped my leaking hard trans lines for all soft hoses as the bolts were all completely seized for the original hard lines. However, a power steerig system sees much higher pressures and they run longer so completely removing hard lines isnt really an option
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
2005 echo rs steering wheel compatible with 2007 yaris??? Xlt00 Cosmetic Modifications (Exterior/Interior) 2 01-11-2018 04:53 PM
'02 Echo cooling fan potential problem tmontague DIY / Maintenance / Service 2 04-07-2015 10:06 AM
No power to engine fan ihateyaris DIY / Maintenance / Service 2 03-26-2015 06:33 PM
Power upgrades for 04 Echo Hatch RS white_rice DIY / Maintenance / Service 7 09-15-2011 10:07 AM
