Old 01-15-2019, 05:36 AM   #18
dogsridewith
Drives: 2007 2-door hatchback
Automatic adjusters drum hand parking foot brake
The guy here who did it that way said it worked with a lot of stops, not a few. It could be the handbrake works better than footbrake, or worse, or not at all. Since the fronts aren't helping, the rears do all the work. But the clever invention couldn't expect people to stop in reverse with the handbrake.
+1 on hard to reach the star wheels from behind. But the drum usually slides right off...Tercel still required bearing disassembly, I recall.
I like to inspect shoes, de-dust, and scrape rust from the edge that can form w/ high miles/use in salt spray.
whistle noise from tyres/rear drum brakes monkeydave Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-16-2017 02:19 PM
drum brakes make squeaky noise jack black DIY / Maintenance / Service 5 08-17-2014 06:45 PM
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
