Old 05-17-2019, 07:21 AM   #11
myfirstyota
3 Yaris and counting..
A little wiring for the trans fan
I decided to go with a relay since I had one gathering dust on my shelf. Here's a drawing of my wiring schematic.
And a little more soldering/heat shrinking for the relay ground. I got this attached but no pic.
Relay mounted. Terminals will also get the soldering and heat shrink. I've got some really big heat shrink, so I'll likely cinch up the split loom that all comes together there.
One thing I've noticed is these cheap relays (not sure if yours is) don't fair well in the open elements (or the engine bay). I've had a few relay failures that were mounted in the engine bay. I'd look into a waterproof one or slather the bottom of the relay (along the seams) in grease to keep moisture out. Food for thought.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
