Underside Body Plugs
I cannot seem to find any info on this in past threads. I was removing my carpet last night and noticed that one of the big (~1" diameter) plug that fills a hole in the drivers side passenger foot well was missing. Now that there is no carpet there it is a gaping hole that you can see the ground through and I would like to cover it up.
Has anyone found a good place to purchase these plugs from, any luck at a dealership?
Yaris Hybrid Limited 2015
They are Here with part numbers
http://www.japan-parts.eu/toyota/us/...5701_hole-plug
![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
Toyotapartsdeal has them for $1.25, https://www.toyotapartsdeal.com/oem/...=NCP93L-BEPRKA) assuming it's the 25mm one. Alternatively, how about some aluminum tape or duct tape?
Edit: alternative 2, take one from a less visible spot like the trunk and cover that with tape. C: |
3 Yaris and counting..
I may have a few kicking around. If you can wait a few weeks, I'm sure I can get them to you
Awesome, thanks guys
just called my local dealership, $8.99 - stupid expensive but by the time I factor in currency exchange and shipping it makes sense to just pick it up locally.
I swapped a plug from the trunk for now but I don't want to leave the trunk with a hole in it so I figured I should pick up the proper plug
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
just buy locally to resolve your problem in short
![]() ![]() Drives: 05 Echo Join Date: Jul 2009
Take a walk through the wreckers and throw a few in your pocket
good call. I already picked up the one from the dealership but after seeing the price I think I'll have to visit a wreckers down the road and grab a handful, they're good to have
![]() Drives: 2006 Yaris Hatch Join Date: Apr 2019
i found all 4 removed in my car after I got my license back ( never really thought when I bought it from the dealer then the suspension ) yeah needless to say you saved your floor now if I could only find the person that thought they didnt need to go back
2006 Yaris Hatch Project Baby Panda going for first an na build then boost in the future |
2ZR swap. DO IT! Ask how!
I posted the diagram and part numbers on a different thread with a similar issue.
| Successful 1ZZ Throttle Body Swap | rabbito | Performance Modifications | 34 | 10-15-2024 07:12 AM |
| Body drain plugs | YAR1S | DIY / Maintenance / Service | 4 | 05-31-2016 06:32 AM |
| Black piece of plastic on underside of body | dinky123! | DIY / Maintenance / Service | 6 | 03-25-2015 10:31 AM |
| Laser plugs? - Awesome | Altitude | Off-topic / Other Cars / Everything else Discussions | 1 | 04-24-2011 08:02 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
