Old 05-31-2019, 08:40 AM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
May I ask, what is the purpose of having both an oil catch can and a breather filter? Don't they both have similar function, taking positive air pressure within the engine and letting it out?
The open-to-atmosphere breather is there to let blow by gasses out of the crankcase when the PCV valve is closed under boost. It would also draw fresh air into the crankcase when under vacuum. At least this is my understanding of how it should work. All that said, I'm having fuel trim issues and not sure if the two are related. I'll monitor trims after I have the F/IC hooked up and the car running- hopefully. LOL.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
