![]() Drives: Yaris 1.4 D-4D 2006 Join Date: May 2019
Shaking at 95-110 km/h
Hi to all, i have 2006 xp90 D4D manual transmission yaris. It is shaking when you hit the gas at 90 km/h to 120 km/h does it in 3rd, 4th or 5th gear. It goes off when you press the clutch. But the shaking is kind of circular motion like left to right.
What can be the cause any opinions? If you go slow on the gas it is ok but when you want to accelerate faster is starts to shake. Thanks in advance. |
Hi, guess no one is visiting this part as no answers had came yet. Is it possible to move thread to service/DIY section?
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Honestly it could be anything. My best advice would be to jack the car up, grab the wheels and give them a shake. Have a buddy look for movement in the ball joints, tierod, and control arm bushings
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
did you also check the motor mounts?
| Humming noise above 50 km/h. Bearing, CV joint...? | jansen.fan | DIY / Maintenance / Service | 9 | 07-28-2017 07:07 PM |
| New Rims + tyres... car is shaking up and down... HELP | G-Ammo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 08-30-2014 05:56 PM |
| 07 shaking | theb | DIY / Maintenance / Service | 2 | 04-19-2013 05:57 PM |
| Differential bearings worn out - car shaking | Unicron | DIY / Maintenance / Service | 7 | 06-13-2012 01:07 AM |
| car shaking after servicing | Canadian | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 11-25-2008 05:40 PM |
