Old 01-03-2020, 01:22 PM   #1
myfirstyota
3 Yaris and counting..
You're right, some sort of custom length driveshaft will probably be needed. Theres actually quite a few driveline and bearing shops just to the east of me in oshawa.
I have a strong desire to keep this as oem as possible though. Not necessarily model specific (ie a rav diff in a yaris), but use toyota parts where possible.
It may be naive of me to think, but if everything is installed where it should be (ie correct driveshaft angles and such) I shouldn't have many problems with broken parts. The ravs are apparently just as bulletproof as a yaris. But maybe I think that way cause of my 4"lift kit. Over 20,000km and no issues yet!
And to touch on Honda, I seen a YouTube video where a guy bolted crv rear end bits onto a civic. Kinda pissed me off a bit lol honda guys have it easy. Awd, endless motor setups, big power for cheap and all the support you could ask for. But easy isn't challenging :)
I do think the rear suspension will be the hardest thing to make work.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 01-03-2020, 01:27 PM   #2
Maritime
Drives: 2008 yaris 5dr hatch
LOL you are correct on Ravs, Had a 1998 that went over 500K with only a few rust issues, I'd still have it if it wasn't written off by shady iunsurance when a lady ran a stop sign and clipped me. As for Honda, I have a Pilot, had a CRV have motorcycles, civics etc. They are easy and bullet proof. My 79 GL1000 had 7 parts that swapped into my 92 civic. when a part works, it works and they use it accross all their platforms.
That said look into Dhaihatsu Hijets (Toyota) they have 4wd systems and manual transmissions etc.
Maritime is offline   Reply With Quote
Suzuki Sx4 AWD...your opinions detroiter Off-topic / Other Cars / Everything else Discussions 19 06-03-2011 12:14 PM
If you were going to get an AWD car ... Thirty-Nine Off-topic / Other Cars / Everything else Discussions 28 07-12-2010 05:46 PM
PINOUT info stereo ozmdd In Car Entertainment + Electronics (audio / video / alarm) 5 12-14-2009 07:52 AM
AWD belta supmet Performance Modifications 26 03-28-2009 02:37 PM
